water cool for newbie?
khicon
What are a good water cool for newbie that never install a water cool b4? I want something that are easy but effective water cool. If someone can post a product and product link to it would be very helpful. Thank you.
Bona Fide
Banned
Jun 21, 2005
1,901
The Tt Bigwater is a good newbie kit, but it's not good at all. If you want a half-decent setup, you need to make it yourself. :)
Ask around, there are a lot of people on this forum that can help you.
HardWarrior
4,400
23
The Corair COOL is a got kit for starters, as long as your just want to cool your CPU.
HardWarrior
4,400
23
Good, that makes it an even better option for new water-coolers and those who don't want to mix-and-match their own parts.
mindwreck
1,585
yeah the corsair system is a really good beginners kits. looks almost like a swifttech kit.
NotquiteanooB
362
Other than the CPU block difference ( Swiftech has about 30 more pins than the Corsair) you'd swear Corsair was cloned or made by Swiftech. The kits are so similar.
racinjimy
73
the corsair cool kit looks like a swiftech 6000 block, HDPE res, DDC pump and the swiftech 120 rad and radbox
it IS all swiftech
I was referring to the new H20-APEX "EXTREME DUTY" SERIES LIQUID COOLING
which has the STORM block/D5 pump and 120.2 rad........................
Pabster
16,986
it IS all swiftech
The H20-APEX is a monster. Top-notch water cooling.
HardWarrior
4,400
23
The Storm is a truly great block, but consider it carefully if you don't like a lot of maintenance and/or want to experiment with coolants. If I was to buy a Storm I'd stick with Hydrx ONLY and thouroughly clean every inch of my loop before bringing it online.
