Water Block solution
xxceler8
80
So I've decided to take the plunge and get a water cooling solution. I did this after noticing the Full tower cases I am consider seem to offer plenty of room to put the unit in.
Can anyone reccomend a system to use?
Sheninat0r
515
Build your own... prebuild watercooling kits are horrible for the price you pay, and it's more fun making your own anyways :D
aigomorla
21,087
3,598
read my sticky linked at the bottom and learn about what a custom setup is.
Learn the blocks, and then come back with hardware profile, and budget as well as the case.
We can show you the correct path to follow after that.
PCTC2
3,892
33
....AND then tell us what parts you are using and what is your budget!
