WARNING! xfx 6970's no longer have a bios switch, and are still using a REF model #
Firestorm007
396
I saw this being discussed over at "H" the other day. This is really sad for XFX. I don't care what they say, because it's not a reference design anymore. They cheapened it and that's the truth. They should've either lowered the price or changed the model #. I for one will never buy one of their cards.
taltamir
13,576
You can follow this saga by visiting any of the 6 or so websites where he has already posted this rant.o_O
good! Bait and switch is deplorable and must be blown to its appropriately severe proportions.
OCZ backpedelled on their bait and switch, XFX will too or I never buy from them again.
Topweasel
5,436
1,657
I find it humorous that he tried to call XFX out about trying to help him out instead of being satisfied that they resolved the issue (when his retailer clearly didn't). It could be somebody with an agenda, though there are times when people get so pissed about something that there's nothing you can do to make them happy. Most likely his retailer was extremely effective in shifting the blame instead of fixing his problem.
Yeah, I mean whom hasn't had a friendly customer rep wink and do something "against policy" to help out someone that was being "wronged" when they shouldn't have.
Important life lesson. Favors you do today will become your job tommorow. The problem is this guy doesn't have the power to help everyone, but probably was being nice willing to help him out, but didn't want it broadcasted because then everyone would expect the same thing.
I deal with the same stuff every day at work. You make an exception on one thing and then everyone expects an exception on everything.
Topweasel
5,436
1,657
I don't know if that was bait and switch but more of bad QC. They had used two other chips with similar performance, I am not sure they were ready for that big of a change and started swapping drives as soon as people brought it up to them.
OCGuy
27,224
36
Thumbs down for XFX, they may have lost my future potential business. That leaves the AMD board partner selection looking pretty lowly.
pcm81
584
9
Why was theer a switch on 6970s in the first place? I though 6970 stock was 880MHz and the 6990 was downclocked 6970 gpu x 2. So the 6990s switch simply unlocked it to a 6970 speed/voltage.
Idontcare
21,110
59
That's a pretty broad brush you are painting with there...even if we just wanted to make generalized characterizations of XFX we still need to recognize that we don't actually know all that much here.
OCGuy
27,224
36
Which is why the "may" caveat was included. Being a customer of XFX, I will watch how this plays out.
ZimZum
1,281
A lot of people use modded bioses with custom voltages and clocks. With Dual bios it keeps you from bricking the card. If something goes wrong you flip the switch and its back to the factory bios. It basically makes the card "idiot proof". Its not a necessity buts its a nice added feature.
tigersty1e
1,963
This is the picture (pcb only) of the card the guy received.
As you can see there is no AMD logo on the PCI-E connector (or whatever is the correct designation).
This one is a reference design and you can see the AMD logo.
amd logo means nothing. powercolor is using the same design as the xfx card. nobody knows the whole story, but from first appearances it seems like it is a design from amd. as to why xfx didn't change the model number more than just adding v. 1.1 is probably something xfx should've done.
http://www.techpowerup.com/reviews/Powercolor/HD_6950_PCS_Plus_Plus/3.html
GaiaHunter
3,650
218
I'm not sure if you understand the concept of reference design and custom design.
Only, I say again, only reference designs have the AMD logo. The guy was thinking he was buying the reference design but he wasn't.
Second, non-reference designs is a common thing.
Third the card you linked is a 6950. I'm pretty sure a 6950 looks quite differently from a 6970.
Fourth the Powercolor 6950 PCS++ has a bios switch with a preinstalled bios that you can flick to unlock the shaders and 6970 core speed (but not the memory speed).
http://www.techpowerup.com/reviews/Powercolor/HD_6950_PCS_Plus_Plus/1.html
PowerColor has built upon this and offers their HD 6950 PCS++ with a custom cooler, custom PCB and a BIOS preinstalled that lets you complete the unlocking progress by the flick of a little switch. With a price increase of $15 over the reference design cards, the price increase of the PowerColor HD 6950 PCS ++ over the HD 6950 reference design does not seem too bad either.
tigersty1e
1,963
so it's a coincidence? sapphire, powercolor, and xfx magically created the same design?
no, what happened is each engineer at each company read the other engineer's mind. but which engineer created the first custom design?
tigersty1e
1,963
listen son, the point here is nobody knows the full story. what we do know is xfx should've changed the model name. this 6000 series has been all sorts of change from the last second 32nm to 40nm change to the drmos to volterra vrm change. as to what should be reference design has probably changed.
Currently, cards are based on Voltera DrMOS components. AMD could not build new card on TI DrMOS due to shortage of the latter, which was said to be the main reason for several delays of the actual Radeon HD 6900 series announcement. Therefore, new PCBs might have those TI DrMOS chips after all.
http://hw-lab.com/amd-expands-radeon-hd-6900-graphic-card-line-up.html
GaiaHunter
3,650
218
As I have already shown you, these configuration allow bios switches, allow 6970 and 6950, etc.
All these PCB configurations are only small variations of the same starting base - that is why they are so similar and it is quite probable that AMD did indeed provided a reference for a PCB using different components, but that didn't prevent Powercolor, for example, from having a bios switch and unlocking the extra shaders.
Still, what does any of this have to do with the OP?
These configurations aren't the reference model. There is nothing wrong by not being the reference model. There is something wrong when you try to pass something for the reference model that it isn't.
If you read the OP you will notice the PCB changes weren't the only changes.
January 16 2011 - Nearly a month ago AMD has presented second generation of DX11-compatible discrete graphics cards targeted at high-end segment – AMD HD Radeon 6900-series – HD 6970 and HD 6950. Both models are based on Cayman die.
Though there are some differences in SP and TMU numbers as well as stock core/memory clocks between these models, this can be easily fixed by HD 6950 BIOS mod (read more here). Shortly after it was discovered AMD has published the following comment:
A number of news sites have reported on an apparent vBIOS flash that effectively turns an AMD Radeon HD 6950 into an HD 6970. While we do include two discrete BIOS ROMS and a BIOS switch for the purpose of trying new BIOS when they are made available, AMD does not endorse the use of the unsupported vBIOS’ on the AMD Radeon HD 6950 as this may lead to unstable performance and/or subsequent failure of the product which is not covered under warranty.
Moreover, AMD takes action to prevent this from happening and prepares a revised version of Radeon HD 6900 series graphic card PCB. As it was explained, new PCB will have different VRM and power elements.
Currently, cards are based on Voltera DrMOS components. AMD could not build new card on TI DrMOS due to shortage of the latter, which was said to be the main reason for several delays of the actual Radeon HD 6900 series announcement. Therefore, new PCBs might have those TI DrMOS chips after all. However, we think, the main reason of PCB upgrade is to block the opportunity to unlock performance config of HD 6950 to get fully operating HD 6970 card.
A somewhat more extensive quote of the article you link to.
Although I'm not sure what you are trying to prove.
taltamir
13,576
considering BFG went under and eVGA avoided fermi, XFX pulling this crap leaves both AMD and nVidia offering lacking.
Dean
2,757
Good point
ah, my mistake...
i guess the only decent player on either team is now eVGA.
Since when is Evga the only decent player? That is an opinion. Every card I ever owned from them died a quicker death than it should have. I never owned one that even reached 2 years of age. So IMO they lack also.
I just bought my first XFX card (with the dual bios) and I hope it sticks around for a while. The only cards for me that never died and are still running strong for years are BFG(R.I.P) and Sapphire. I was looking to get a Sapphire one, but just got too good of a deal on the XFX card to turn away from it.
tigersty1e
1,963
but evga started offering only 2 year warranties for some of their products.
i hope lifetime warranties don't expire (pun) in this industry.
Seero
1,456
Let me see. AMD clearly stated they will not be responsible on OC, yet the releases reference card has a switch to do exactly that.
AMD is not at fault as they do not sell video cards.
XFX stands out and stated that they will provide warranty on the use of that switch. All credit goes to AMD.
AMD video card owners won't complain, but AIB manufacturers do. So AMD provide a work around, but revisioning their reference board and the BOM that is used to build it.
Now XFX uses the new design from AMD, and they are now at fault? The provider supply different goods, what can AIB manufacturer do? The old design is obsoleted.
As to the AMD logo, do you guys remember that AMD doesn't produce video cards?
It will be more interesting when people starts to RMA their old card and get a new one.
There is nothing illegal going on. That switch is not supported by AMD, the one who design the board. In fact, their shouldn't be a switch to begin with. If they do support OC, then they simply use the OC bios as the bios on reference card.
Keep in mind that just because the card looks different doesn't mean they are now using cheap parts. They always use parts that are up for the task or they will face sea of RMAs. However, by removing the switch, assuming the ability to OC, some parts may be an overkill. In other words, those you don't OC their card or have waterblocks won't lose anything. The new revision still runs at the same stock clock and voltage as resulting in the same performance.
The reminding question isn't about the switch, but whether the card can be OC as if it is using BIOS2. If it can't, then fanboys who believes they are once self proclaim enthusiast and overclocker can cry on streets as their dream has just got shattered.
As to XFX, they still provide warranties on cards with the switch, but if they receive it back via RMA, then they simply return it with one that doesn't have the switch. Hey, that is way better to tell customers that their card as passed its double lifetime warranty right?
Don't get me wrong, I am not saying AMD is at fault, as all they did is to provide an easy way to OC. Users however believes that they are eligible of RMA their card due to it being killed through OC is a joke. Again, customers are always right, so bye bye switch.
And yes, we can all go back to several years ago where OC video card requires soldiering.
Outrage
the switch that are being discussed here is just a switch to revert back to the original bios incase you fail flashing the bios. This is not about the switch on the 6990 cards...
3DVagabond
11,951
204
You took AMD's warranty disclaimer (not warrantying cards that are operated outside of factory settings) and spun it into all of that. The only thing we know that exists in all of that is some XFX cards have switches and some don't. XFX warranties both models for the consumer, not AMD.
For every generation they release reference designs. After awhile they release custom designs. Some are better, some are cheaper. Look on Newegg and this card is in the latter catagory. That's what always happens. It happened before there were BIOS switches too. Just like there were always warranty disclaimers. Even before there were BIOS switches. There is no evidence to prove any of the relationships you are alluding to here.
Question: Who is marketing a cheaper non reference design masquerading it as the reference model?
Answer: XFX, AMD, or possibly someone else. We have no info to answer that question, but with the XFX name on it, they are responsible unless they give us information otherwise. If the AMD logo was on the board, as with other known reference designs, I'd immediately think it was AMD. It's not though. Only XFX's branding is on the card.
It doesn't mean that the board is in fact not an AMD design. We've seen pics showing what appears to be the same design from other board partners. Are they too supplying it as their current reference design? It could be a design from some 3rd party supplier of PCB that all these companies are using. Who knows for sure?
Finally: Not having the bios switch does not prevent O/C'ing. It makes modifying the BIOS a risky proposition because you have no backup BIOS to fall back on if the card fails to boot after modifying the BIOS. Nothing more. Nothing less. The 6970 can't be unlocked to anything else, so it doesn't affect anything that way either.
GaiaHunter
3,650
218
This post is completely mis-informative and misinformed.
1st) The bios switch on the 6970 doesn't offer any OC option ans as already said, this isn't a 6990 and its AUSUM switch.
2nd) I'm not sure in what you are basing your assessment that this is a new reference design made by AMD. If you are basing it on the fact that several AIBs use a similar design, you should also know some of those designs do include the bios switch, as for example the powercolor 6950 pcs++ that even have an unlocked shader ans core oc bios.
The decision not to include the bios switch was XFX alone.
3rd) The AMD logo on a PCB guarantees that for example any water block says it compatible with the 6970 reference design will fit on the card.
That is one of the complains of the OP - he had a waterblock for a reference 6970 and it didn't fit since it wasn't a reference design.
So reference designs and AMD logos aren't just some kind of excuse or something that doesn't matter for the consumer.
