I have a 17" LCD monitor with pixel pitch: .264, this shows very little screen door effect, not enough to bother me.
My brother just got a 15" LCD monitor with pixel pitch: .297, this shows the screen door effect and is very noticeable compared to my 17".
Then I thought to look up the pixel pitches of both 15" and 19", which are .297 and .294 respectively. My warning is to go and check one out before you buy. You were already supposed to be doing this anyway, but because of a certain brand being better than another, you might just skip that step. That and the fact that no retailer has every LCD on display. But I urge you to go and check out a 19" LCD screen before buying. Check for this effect, because it is quite bothersome.
