Warning - Crest pro-rinse mouth wash appears to stain teeth.
Brown stains between the teeth... My wife has little dark dots now :disgust:
I guess the doc can get rid of them.
Just an FYI, the Crest Strips work great. I used them right before I got married to make my teeth whiter for the photos, was very pleased with the result. Expensive tho 🙁
😕 that's fvcked up! Are you sure it's from that stuff? What a nightmare!
Thanks for the post- I've been using the stuff for about 9 months or so- no stains (i think...need to go check) but I'll throw it out now
Pretty sure because the came after she used the product and other people have reported similar things.
If you've been using it for 9months...I think it might be ok.
I have been using it a while now and have not noticed any staining. Is your wife prone to cavities?
class action lawsuit ftw!
and then as a settlement you will all get coupons in the mail for 25cents off your next bottle of mouthrinse. 😛
