Warm XP Pro 79.99
Samus
1,405
7
buying this illegal oem media is just as bad as pirating. do you think MS is getting any money from these sales?
dorkbert
68
Originally posted by: cpals
They're Dell OEM cds??
DELL CDs will only install on DELL systems without activation and CD key. Attempt to install on any none DELL system will trigger the activation code.
MrBLUNT
Guest
Apr 25, 2002
251
Have you even tried this? Y say things that you dont know?
pxc
2,001
MrBLUNT is correct. And yes, I have also tried it. You can just pop one of these CDs into a semi-recent Dell (since XP came out) and you won't be prompted to enter a key or have to activate it. Install it on a non-Dell system and it installs just like a regular OEM copy of WinXP: you'll have to activate it and get prompted to enter a key. Of course WGA is new and you'll have to validate WinXP again or use a workaround.
The Dell OEM CDs have a couple of other minor changes: a small directory on C:\DELL is created with 3 small files (1 htm, 1 gif, 1 jpg) and the start menu will have a Dell Solution Center entry under the Run... option. Delete those 2 things and it's pretty much a regular installion of WinXP.
Schadenfroh
38,416
4
My father bought it and i installed it for him. They were OEM dell branded CDs, they installed just like normal xp pro and they activated just like normal xp pro. It was on an AMD system even, so the pc had nothing to do with dell. It works fine to this day and i can tell no difference between it and any other xp pro that i have installed.
funboy6942
15,362
416
Yeah thats why my dell XP cd has been installed on 4 different motherboards none of them a DELL! I have never had any trouble doing an update and using my Dell XP cd.
Should note though OP this $79 deal is CD ONLY no COA so if you dont have the serials you need to find some. They have it there with the COA for $99 I think I saw.
Now my windows 98 Dell cd is a different story. It will only install on a dell unit.
jkyle
2,387
True if installed on a Non Dell unit it will work but you MUST HAVE THE COA... No coa = usless cd. The nice part if you do have a dell unit it wont ask for COA code and will validate the WGA check without ever typing in anything.
nealh
7,078
Require the COA? Click here
Microsoft Windows XP Professional
Windows XP Pro Full Dell CD, Key,
(EULA) End Users License Agreement on CD
this from the website..note under description..it says it comes with XP Pro cd and Key
so why would you need the COA?
esquared
Forum Director
Oct 8, 2000
24,772
5,908
It looks like they also sell the disc with the COA for 15 more. here
deptrai
118
Why do you care for M$? Do you think they will go bankrupt bacause of you not buying this at retail store?
gnubea
98
Because buying a CD in a way that M$ does not make money is just like getting a pirate copy regardless if the CD is made by M$ or not. If it isn't legal to use it, why bother buying it and use it while you could download it from some p2p sites ?
We don't care M$. We care for our own asses.. oops assets.
nealh
7,078
why would this place advertise on their website like they do if it was illegal...they indicate it is legit software....
Hacp
13,923
Blah I can rip my dell CD and burn it for you guys for 50 bucks! Sry to threadcrap but i gotta make $$$$.
apoppin
34,890
alienbabeltech.com
not true
you do not need the COA . . . just the key
Gast
317
Hrm, so if I understand this correctly, there is an activation keycode in a text file on the CD? Can anyone verify that?
whatmeworry
45
stfu
earsjr
234
stfu
rofl. sorry, it was funny.
