warm: ThinkPad R40 1,169.10 for 15 inch, 1.4 centrino
hconnor2
130
ThinkPad R40 (IBM Think Express Program)
Your price
$1,169.10*
warm because its an IBM, which seems to be getting much better reviews than DELL.
details:
General
Model name 289783U
Description ThinkPad R40 (IBM Think Express Program)
IBM Web Price* $1,299.00
SuccessLease® for Small Business*** $42.00/mo. for 36 mos.
Software[12]
Operating system provided Microsoft Windows XP Professional
Communications applications[9] IBM Update Connector; Adobe Acrobat Reader; IBM Access Connections
Utility applications PC Doctor diagnostics; ThinkPad Configuration Utility; IBM Rapid Restore PC; Norton AntiVirus 2003 OEM Version
Productivity applications Access IBM
Other applications provided IBM Drive Letter Access;
Supported operating system Microsoft Windows 2000, Microsoft Windows 98, Microsoft Windows 98 Second Edition, Microsoft Windows NT 4.0, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional
Architecture
Bus type/architecture PCI
Bays Ultrabay Plus
Indicator light Yes
PC Card support T3
Display/Graphics subsystem
External display supported Yes
Simultaneous external display Yes
Screen type description TFT
Viewable image size (diagonal) inches 15.0
Screen illumination Backlit
Max colors or gray shades 16777216
Maximum Resolution 1024x768
Graphics
Video RAM std/max 16MB / 16MB
Description ATI Mobility RADEON 7500
Graphics type XGA
Video RAM type DDR SDRAM
Max resolution 2048x1536 16777216 colors
Max colors (with max video RAM) 16777216
Graphics bus interface AGP 4X
Max resolution external display 2048x1536 16777216 colors
Video on Planar Yes
Processor
Processor (CPU) Intel Pentium M processor
Processor speed[1] 1.40 GHz
Front side bus (FSB) 400 MHz
Internal L2 cache memory size 1 MB
System memory
Memory (RAM) std/max[8] 256MB / 2GB
RAM slots total 2 SODIMM
RAM slots available 1 SODIMM
Memory speed 266 MHz
RAM type DDR SDRAM
Module specifications PC2100
Hard drive
Hard disk size (GB)[4] 20 GB
Interface type ATA-100 (Enhanced IDE)
Rotational speed 4200
Optical device
Optical device CD-RW/DVD-ROM Combo IV
Device interface EIDE
Audio
Integrated speakers 2
Speaker power rating 1.0 Watts
Volume control buttons Yes
Speaker Quantity 2 (Internal Speakers)
Number of speakers 2
Audio chipset SoundMAX
Audio data width n/a
Audio on planar Yes
Communications
Fax/modem description 56K V.92 designed modem
Fax/modem speed[3] 56Kbps data/14.4Kbps fax
Infrared port Yes
Infrared port speed 4Mbps
Wireless type LAN
Wireless standard[10] Intel PRO/Wireless Network Connection 802.11b
Wireless speed 11Mbps
Ethernet description 10/100 Ethernet
Ethernet interface type Ethernet-Integrated
Ethernet on motherboard Yes
Accessories
A/C adapter 72 watt
Worldwide A/C compatibility Yes
Port replication Optional
Standard features
Pointing Device Type IBM ThinkPad UltraNav
Keyboard type[11] Full size
Keyboard light Yes
Power management
Heat emissions 72 W
Sound emissions 40dB
Battery life min/max[6] 6.1 Hrs (with 1 battery)
Battery type(s) 8 Cell Lithium-Ion
Charge time (on/off) 3.0 Hrs/ 3.0 Hrs
Expansion options
Plug and play support Yes
Parallel Port Type 1 (EPP), 1 (IEEE 1394)
Port connectors 2 USB 2.0, AC adapter, Expansion Bus port (for Mini Dock or Port Replicator), External Display, External microphone, Headphone/Line out, IEEE 1394, Infrared, Line in, RJ-11, RJ-45, S-Video out
Slots total (available) and type 1(0) PC Card
Security Chip IBM Embedded Security Subsystem 2.0
BIOS type Flash ROM
Core Chipset Intel 855PM
Infrared Support Yes
Weight & dimensions
Weight[2] 6.7 lbs
Height 1.59 in
Depth 10.5 in
Width 13.0 in
Travel weight 6.30 lbs
Security
Security features Hard disk drive password, IBM Embedded Security Subsystem 2.0, IBM Security Slot, Power-on password, Supervisor password
Limited warranty[7]
Type of service[13] Customer Carry-in Repair or ThinkPad EasyServ
Limited warranty period One year parts and labor (system battery: one year)
teKillah
241
I think its at IBM.com
http://www-132.ibm.com/content/home/store_IBMPublicUSA/en_US/ad.html?&ca=rop&me=W&met=inli&re=hho
Also there are a bunch of IBM Discover Card specials on X31, T and R series.
http://www-132.ibm.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=-840&storeId=821258&langId=-1&dualCurrId=201298&categoryId=2302835
I would recommend you note down the part number and call IBM directly and they would most likely give you that price.
You dont have to use your Discover card and currently shipping I think is 2-day UPS directly from Hong Kong x
InlineFive
9,599
This system is insanely loud at 40Db and I would first consider the T41 for $1,400 instead.
