Smokin Gunn
128MB $15.99 Shipped Free HERE
512MB $36.99 Shipped Free HERE
These are USB 1.0 Drives I believe :roll:
I-Stick is the smallest and lightest USB Drive. The thickness is a mere 2.8mm! Got two pennies? Put them side-by-side and you`ll have the length of our I-Stick. Fully compatible with any USB port. You can plug our I-Stick into any USB port and start working right away. No USB reader, no adapter, no kidding! It?s a new generation flash memory card! Not just a USB Drive, the I-Stick is geared to be the most versatile flash memory card on the block. Our I-Stick can go straight from your digital still camera, PDA, or MP3 player directly into the USB port on your laptop or workstation CPU. No need for a USB reader! Powerful? The I-Stick`s current capacity ranges from 128MB to 1GB.
Advantages:
* Small form factor
* High compatibility
* High performance
* High data reliability
* High capacity
* Easy design-in
Advantages:
* Small form factor
* High performance
* High capacity
* Easy design-in
