Specs:
17" Diagonal Viewable
Active Matrix TFT Panel
True 1280 x 1024
0.264 x0.264mm Dot Pitch
Brightness: 250cs/m² (Typical)
Contrast Ratio: 350:1 (Typical)
Color
isplay 16.7 million color
Viewing Angle: 120° Horizontal, 115° Vertical
Scanning Characteristics:
Horizontal Frequency: 30-82KHz
Vertical Frequency: 58-75Hz
Compatibility:
PC: VGA up to 1280 x 1024
Macintosh: Up to 1024 x 768
Signal Inputs:
Video: RGB Analog (0.7Vp-p)
Sync: HV Separated (TTL)
I/O Connector:
VGA Input: 15pin D-sub Male
Audio input: 3.5mm Stereo jack
Earphone: 3.5mm Phone jack
Power: DC power
Model #PV720
Sam's Club Item #: 897546
The biggest thing of note is the fact that this monitor only supports ANALOG connections; someone else can point out the pitfalls of that as I am not too learned on the subject.
If the deal sucks let the post sink. If the monitor sucks, let us know.
Edit: Link
True 1280 x 1024
Color
Compatibility:
Signal Inputs:
I/O Connector:
Power: DC power
Model #PV720
Edit: Link
