WARM: ATX Case at CompGeeks for $29.50
Hugenstein
419
The case by itself is $18.75.
It is extremely light and very flimsy with the sides and top off...then again you don't run the computer with the sides and top off.
RoadSplat
54
Just got this case. Yeah it is flimsy but for the price it's an alright case. Just needed something to throw together for my wife
stockjock
4,205
I've bought 2 of these cases and they are flimsy...and the keyboards are real flimsy and the shift key is real small, so you keep missing it...but all that said...its not a bad deal for a low end system....I did have one problem with one of the cases....the metal standoffs wouldn't screw into the case metal back, the holes were to small so I had to dremel the holes a little to get the standoffs in.
