WaPo & ATP&N exposes pure hypocrisy of GOP base
Amused
57,547
20,262
pcgeek11
22,418
5,019
What happened in those four years that changed their minds so dramatically?
Obama did nothing. Time for a change.
I personally think the US should have acted then and maybe things would be better now.
I do not think that the numbers posted in the OP mean anything like what is implied.
fskimospy
55,850
Obama 'did nothing' in large part because of heavy Republican opposition to intervention in Syria, lol. That has mysteriously evaporated. I wonder why? Hahaha.
Are you attempting to claim that had we polled Republicans on intervention in Syria on November 1st, 2016 we would have seen results that were generally similar to this recent polling?
pcgeek11
22,418
5,019
Bull Shit. Obama drew a line in the sand and then when Assad told him to get fucked he did nothing. It also depends on what you mean by the broad term "intervention". It has not evaporated. I am very much against inserting troops on the ground in Syria, and the ones that are there should be pulled out. Air strikes are quite another matter.
I'm not attempting to claim anything. Any answer I would make with respect to what would happen if a poll were taken in Nov 1st 2016 would be a guess nothing more and pointless as the OPs supposition.
fskimospy
55,850
Have you somehow thrown the fact that congressional Republicans refused authorization for a strike down the memory hole?
Of course you're attempting to claim something. You said that the reason for polling differences was the passage of time. Presumably that means if you think four years led to such a dramatic reversal by Republicans then 3.5 years would have led to results that were at least mostly similar, assuming that time was the governing factor. This is just common sense.
You are desperately trying to avoid the obvious reason for the reversal. Their tribe was pressuring them to oppose intervention when Obama wanted it and their tribe is pressuring them to support it now. This isn't brain surgery, it just requires no longer engaging in motivated reasoning.
pcgeek11
22,418
5,019
OK, If you say so it must be true.
ivwshane
33,768
17,414
Fuck you, you god damn liar.
https://forums.anandtech.com/thread...n-syria-is-path-to-war.2223221/#post-32934670
https://forums.anandtech.com/thread...ndsey-graham-say.2227571/page-2#post-33034094
https://forums.anandtech.com/thread...ssad’s-forces-in-syria.2325663/#post-35148500
https://forums.anandtech.com/thread...-forces-in-syria.2325663/page-2#post-35151151
https://forums.anandtech.com/thread...-forces-in-syria.2325663/page-2#post-35151291
Once Obama was denied by Congress is when your tune changed. You are such a partisan hack!
Jan 25, 2011
17,193
9,740
Hey if the panderer in chief can sit and say Obama should have done something before even with his, what, 20 tweets saying Obama absolutely shouldn't have struck Syria why can't the base be "flexible".
brycejones
30,339
31,417
Then enlighten us with your vast knowledge.
64 point swing and it has nothing do with the guy giving the order belonging to the correct party. While the difference for democrats is only one point.
Seems like one group is much more consistent on this issue regardless of who is office than the other group.
Perhaps if you haven't changed your opinion maybe you should back out of thread and let those who were part of at that 64 point swing explain thier rationale. You would appear to be the least able to explain why it was bad then but ok now because you haven't had that mental evolution happen.
