Ok, I have never used linux, and Im new to computer hardware and all that. I want to install debian linux on an old IBM aptiva comp with the following specs Im pretty sure it uses. Thats all I know. Dont know where to download (and burn) the OS or how the drivers work. I dont even know if the following is linux compatible, so much junk on google, I dont even know where to begin. I also dont know what to do with the current operating system. I want to completley get rid of all evidence it has win 98 though.
All the netorking info, I am not sure about. All i know is the comp is behind a router and the router has dhcp enabled.
pentium 2 400mhz 64mb ram
Windows 98
cdrom (or dvdrom) drive: Hitachi GD-2000
NIC: Linksys LNE100TX Fast Ethernet Adapter
Onboard sound: Crystal Pnp audio system MPU-401
onboard graphics: Rage Pro Turbo 2x AGP (mach64)
The whole point of this is, I want to learn how to install linux and how to implement it, then learn the OS, and eventually be able to use it as my main OS. Links, info, anything would be helpful. If you want me to give you more information, I will try. Thanks in advance.
Windows 98
