Wall Mural Advice
Status
Not open for further replies.
JoeFahey
2,163
I am in the process of repainting my room. I am using a darker tone of green for an earthy look. I also plan to paste a mural of some mountain/forest scene on one of the walls that would complement the paint color. I know I could use a program like Rasterbator to create my own image, but I want a higher resolution and I want to avoid the seam-lines.
Why am I finding massive price differences in certain murals?
eq:
This: http://www.muralsuperstore.com/catalog/mountain_view_wall_mural_by_envi.htm
vs.
This:
http://www.muralsyourway.com/kent-falls-mural/
General advice from anyone who has used a wall-mural?
Thanks!
EDIT: The wall is about 7.5'x8'
11,391
Well, you can get a hella big map; I have one put up on the wall at work and it's put together - like you said - like wallpaper. If you're doing a full wall mural, I doubt you'd find something pre-made as it most likely is not a "regular" size for posters.
BoomerD
66,716
15,116
You mean like this?
imag.aspx
I know you're a youngster, but dude...improve your google-fu!
http://www.google.com/search?gcx=c&sourceid=chrome&ie=UTF-8&q=wall+murals
Status
