Question Wall mounts for router and modem
zigzag03
I'm looking to mount my router to the wall behind the desk. There are a variety of products available, but none of them even show how you might handle cable management. It seems to me that your average mimo router with 4 or 5 antennas would need to be mounted with the antennas up, which is also the same side the connections are on. It would be good to be able to pull the cables up behind the mount, but everything I see holds it tight to the wall forcing cables to come up over either side. Has anyone seen a solution that allows the cables to come behind mount? If I were more of a carpenter maybe something could be fabricated, but was hoping not to put my minimal skills to use to solve the problem. Thanks, zz03
