Considering ordering the Samsung U55ES6500 today, but have a question about wall mounting it. Samsung recommends their own slim mount - WMN250M - but I can't find out what the horizontal distance between screw holes would be on the wall. This is being mounted on a brick fireplace and there are two unused vents that the TV would hang in front of - and these would be right at the height I'd probably need to hang the WMN250M at. I have about 20" of width that I could lag bolt into but if that mount has to be bolted wider than that it won't work.
If that's the case, can a "standard" metal wall mount work with this TV?
