WALL MOUNTING FOR KLIPSCH SPEAKERS
WhoseNext
12
Where would I find speaker brackets for wall mounting or even speaker stands that would work with the Klipschs promedias?
konichiwa
I don't know about the Klipsch, but they might have a little hole in the back, you can just put a nail in the wall and mount them on that. Not the best solution, but it works in a "duct-tape" sort of way. :)
RC
1,358
4
Several months ago I purchased speaker stands for my Klipsch promedias directly from klipsch.com
Irongolem
Forget about the floor stands from Klipsch. Just goto to radioshack and pick up a pair of stands for 49.95. A lot cheaper than what klipsch is selling theirs for. Believe me, the ones from the shack work just fine.
-Irongolem
The Sauce
4,741
34
Bologna! They say that they are universal but I bought a $50 pair of brackets from Best Buy and they didn't fit...I had to cut them down. I would definitely get them from Klipsch if at all.
