Wall mounted flat panel TVs--wiring?
Mermaidman
For those of you have have wall-mounted flat panels, what do you do with the wiring *if* you did NOT run wires inside the walls? Would appreciate :camera: of your setup.
I'm thinking of getting a plasma and putting it on a wall. I've seen some guides on the web, but no photos of external wiring.
Yeah, just buy some raceway from Home Depot. I believe they sell the Wiremold brand linked above. It's good stuff and easy to use - screw the backing into your wall, run the wire inside, then slide the cover over and voila. You've probably seen it used on phone lines before, it's used in places where they can't run it inside the walls (like if the wall is brick or stone).
