I can't think of a single good way to sell a mountable DVD player. They're supposed to lay flat. The only way to "mount" it would be to have a small tray attached to the wall, which you can easily by seperately and then you get the benefit of buying whatever DVD player you want!
Also, if your LCD is wall mounted, I highly encourage you just bite the bullet and buy Blu-Ray or HD-DVD.
