Wall Mount Recommendation
lupi
32,539
260
I'd like to move my plasma from on the tv stand to the wall with a mount capable of swiveling. I was looking here.
Any recommendation for which to chose from? I have a 42" panny, but I'd like have room to upgrade to a 50-60" at some point.
sivart
1,786
don't do it.
How do you hide the wires? -- or do you wire everything through the wall? Did you install a power outlet up on the wall?
Where do you store the other components? (in the stand it is sitting on)
What if you want to re-arrange the room?
Will you need to build a separate wood support to make sure you hit enough studs?
