Wall mount advice for UN65KS8000?
swchoi89
200
Hi all,
Can someone please recommend a good brand for wall mounting my 65" KS8000 samsung TV? I don't need those tilts or whatnots. I just need a basic/simple one.
Also, is there a guide on what other accessories I need to buy such as extra screws, etc?
Thank you in advance.
Feb 25, 2011
16,983
1,616
Most mount kits come with all the hardware (screws, etc.) you need.
For lighter-weight stuff, I'll use some fender washers and drywall screws, rather than the included lag bolts, since the holes are smaller and easier to repair.
For a 65" TV, you'll probably want a mount that attaches to multiple studs. (Drywall anchors are right out.) If you need the TV mounted not-quite-on-center-to-the-studs, screw a couple 1x3 boards into the studs, paint them the wall color, and then attach the mount to the boards wherever it is you need it.
