wall/ceiling painting advice!
Status
Not open for further replies.
oddyager
3,398
Hey all, could use some of your interior design advice here. I have a section of the room like so in the attached images. The wall will be soft iris and the ceiling white. My idea was to have the support beam on the ceiling (goes from wall to wall) match the color of the ceiling and the section that curves down towards the wall also match the white color. However looking at it from different angles it does look a little bit odd? I also considered coloring that whole block soft iris as well to match the wall but the area it curves up into the ceiling might not look so hot? What do you all think?
oddyager
3,398
Status
