- Mar 7, 2004
- 52
- 0
- 0
Hi there,
I just transplanted and upgraded from my beloved Lian Li to el cheapo case to take advantage of 120mm fans and normal front-to-back airflow. Here's what I've swapped out so far:
LIAN LI PC-60APLUSII >> CoolerMaster 431 Elite Plus
AMD Phenom 925 2.8Ghz (95w) >> Amd Phenom 970 3.5Ghz (125w)
ASUS M2N-E > M5A97-EVO Motherboard
SAPPHIRE Radeon 5450 (fanless) >> SAPPHIRE 6570 (w/Quiet fan)
Obviously not use for gaming!
I used an older (2008) but new OCZ 500 SXS 500w power supply that I had as a backup handy (it's black and has nice screened cables)
My problem is that having setup everything using PWM 120mm Arctic Cooling fans I have this super annoying Waaahh Waaahh sound that is louder than the fan spinning sounds.
I even changed out the power supply fan using another AC PWM and it's still doing it.
It seems like it's a resonance sound as when I change the fan speed on the only unchaged fan left (the default Cooler Master 212 EVO 120mm) it doesn't change the Waaahh Waaahh sound?
If I hold my hands against the side panels there is also no change.
I'm at a loss as to how to find out what it might be?
My Lian Li didn't do this
Any ideas what I can do to find the cause?
