W7 system protection/restore help
rsutoratosu
2,716
4
I have a windows 7 laptop that I can't figure out the System Protection.
The system used to automatically create restore points, I see it in the task scheduler that it creates them and does not fail. When I go into the system restore button, it says there are no restore point available.
I manually created one and it shows up in the system restore but when I reboot, that manually created restore point is gone.
DirkGently1
904
Have you allocated enough space for it? make sure the slider isn't all the way to the left under 'Disk Space Usage'.
rsutoratosu
2,716
4
yeah, i turn it off / on, its using 10% of 250gb drive, i can manually create like 4-5. I google around, seems like its a buggy software.. they have been after market system restore software thats better and more stable.. going to try some of the "fixes"
