BathroomFeeling
When my brand new system came home, I installed W7 Ultimate x64 on it, patched it up, and it worked great for the next two weeks. Then one day it decided to stop my internets! Basic things I did were of no help. Luckily I still had my old XP junk system, and the fix sounded simple enough. Destroy "Bonjour". Switched systems, tried it, but no dice. Switched again, looked again, ad nauseum.
What followed were four hellish days of trying to get the damn thing fixed. I tried all manner of fixes posted far and wide across cyberspace. Did the "netsh" thing, and the "route delete" and "ipconfig" thing. Did the auto troubleshooting thing, did the manual disable/enable of adapter thing. Did the uninstall/reinstall of my LAN card. Did the manual settings of IP/DNS/Gateway/etc... addresses. Did the disable IPv6 thing (both untick, and full regedit disable). Looked for Bonjour and its associated files "mDNSresponder.exe" & "mdnsNSP.dll" in both of the the Program Files folders. Did the "DhcpConnEnableBcastFlagToggle" & "DisabledComponents" thing. Did the "gpedit.msc----->Unidentified Network" thing. Looked for any mention of "##" and "bonjour" in my msconfig and task-manager. Removed all unnecessary startup programs. Even uninstalled my AV and disabled Windows firewall. Nothing.
I had one hair left, and I picked it and stroked it for luck for my next task. I backed-up what little I did in those two weeks, and destroyed W7 (yes, even the hidden partition) for a fresh and clean install. Two partitions this time. It should work, I mean no data was going to be retained anywhere. It's going to be like 2011.. two weeks ago! I grabbed the latest drivers off the interwebs, basic stuff mind you, no bloaty Asus junk or other useless crap. Install W7, install mobo drivers, install lan driver, test. That's it. So what happened?
Still no internets.
I wanted to chuck the whole new computer out my window! When I calmed down, I thought it probably was the Intel Gigabit LAN on my mobo that was acting up. So I used my the Realtek LAN card from my old system to see if that would work. No. No it didn't, same problem.
It's not the cable wire, because I'm talking to you right now. It's not the LAN, because I checked with an alternate. I don't have any other networks in my house. I don't use a router (direct cable to LAN connection). It's not the system, everything was working file until that Tuesday (I even had Bonjour & other junk working for a week!). It's not my ISP, they tested the signal, and it's all good. It's not my eyes, I have 20/20 vision. It's not my mind, I still have my marbles. It's not reality itself... well maybe it is, could be I'm just imagining my problem and hoping for my subconscious to help me through your potential answers, and I'm really on some hospital bed somewhere in a deep coma. So it's either Windows7 or the fabric of the universe.
Please help this broken man with his broken system. I don't like using this slow-ass loud-as-banshee system!
Still no internets.
