W2K will not recognize my PYRO 1394 drive kit!!!
777php
3,498
I have a ADS Technologies PYRO 1394 hard drive kit with a 40 Western Digital 7200 rpm drive set to master.
I am trying to use it on my Dell 5000 laptop with a Western Digital PCMCIA card.
I've tested the drive on another computer and it works fine, the PCMCIA card works fine, just imported a DV.
I'm stuck. I can't seem to find the right drivers for it. Everytime the new hardware prompt pops up it shows the device as "_ _"
Anyone else have this problem?
Jun 30, 2001
140
Obvious things to check:
- do you have latest Win2K SP?
- does the drive work on another Win2K installation?
If it works on another Win2K box that isn't your laptop, then the problem is probably something to do with your laptop.
777php
3,498
I have the latest service packs....i also have a HP Kayak Workstation with a maxtor 1394 pci card, I get the exact same errors there.
