Winchester
I am putting up a server for a county office. All of their personal computers have W2k on them. I am wondering which OS would be better between the two. I have heard that W2k is more stable, but that was a while ago. They are both the same price so that is not a factor.
As of right now, the server will only be a file server, to about 5-6 computers. However, it may become part of a larger network for a small county courthouse, where anyone in the courthouse can get files off of it. All I am needing to do is setup about 6 users for access. I just want the best OS. (unfortunatley, Linux can NOT be used since the programs they will use are not compatible with Linux)
Thanks,
BTW, just for you drooling geeks. Here are the specs
PowerEdge 1600SC:
2x Intel® Xeon? Processor, 2.8GHz, 512K Cache, 533MHz Front Side Bus, 1.0GB DDR SDRAM, 2x 146GB 10K RPM Ultra 320 SCSI Hard Drive, CD-ROM/DVD-ROM: 32X IDE Internal CD-RW/DVD ROM Drive, Tape Backup Unit: PV100T, DDS4, 20/40GB, Internal TBU, No Controller, Hard Drive Configuration: Hot Plug SCSI Drives Attached to embedded SCSI controller, No RAID
Thanks,
PowerEdge 1600SC:
