W2K Home network trouble
bakeweasel
I have two W2K machines on an office lan. Both are connected to an SMC router/hub to share internet...
Internet works fine on both machines. I have the network settings the same on both machines, however, machine #1 can see shared folders on machine #2, but #2 cannot see shared folders on #1. I can see both computers on the network from both #1 and #2.
One difference I did find was that
#2's shares show the following: ADMIN$, C$, IPC$, shared folder
#1's shares show the following: shared folder
Is there a service running on #2 that is not running on #1 and how do I determine that?
Any advice much appreciated.
Here is the error I am getting when I click on computer #1 (from computer #2) under "computers near me":
\\computer #1 is not accessible.
Logon failure: the user has not been granted the requested logon type at this computer.
As I said before, when I try to access computer #2 from computer #1, everything works fine.
Thanks for any ideas.
eriK
Thanks. I tried it to no avail. I get the same error. I think it has something to do with the difference in the default shares of each machine as I described above. Do you happen to know how these shares are set up? (ie IPC$, C$, and ADMIN$)
The shares that end with $ are admin shares which only an administrator can access. Is the account you are using to access the share an administrator on #2? You need to use an administrator account that actually resides on #2, not just one that resides on #1 that has the same name because they are not the same account.
