I hope this is the best place to post this - I'm not sure what is causing the problem!
I'm having a strange problem with my Epox 8K7A+ motherboard that I need some advise on.
When I use a program like EAC to create an MP3 file I like to use Winamp / Tag&Rename to set up the MP3 tag properly. However when I try to save my changes W2K gives me an error...
File is locked by another program / set to read only. Unable to apply changes
... or something to that affect.
Everything was working fine in my old Abit BE6-II board with exactly the same hard drives etc.
The same thing has happened when I tried to rename a film after running it through EasyDivx.
The only thing I have done different is use ribbon ATA100 cables to attach the hard drives to the Epox IDE1 and IDE2 controllers (not the Highpoint ones, they are currently disabled) - on the Abit board I used normal ATA33 cables as the controllers were not capable of ATA66 and ATA100.
But due to the layout of my case I have had to put my hard drive (set as a master) on the ATA100 cable where 'slave' is indicated, and my DVD Rom, set as a slave, attached where the 'master' is indicated.
What difference will this make? Could this, for some reason, be why I am having a file locking problem? Other than this things seems to be running very well.
Any ideas?
Any ideas?
