Hi all.
I was trying to apply GPO to my domain which consist of 2 machines 1 running W2K-AS and one running W2K-Pro.
I have configured the policy at the domain level on the AS well I am only testing the "Disable personalise menu" policy. I Disabled it and restarted the AS and it worked fine as the personalise menu setting is no longer visible.
Then when I went over and log on to the Pro the setting was still there. I know that the GPO at the domain lever should override the local settings. I checked the local settings anyway and that particluar setting was not configured under local setting.
I made sure that no one is set to "Deny" access for the "Apply policy" check box.
Would someone have any idea as to why this is happening? Is there some other setting that I may have forgotten to set?
Thank you in advance.
