Question W10 won't read USB sticks larger than 1GB
Geos54
HELP! This is really bizarre. My W10 Pro 20H2 File Explorer won't recognize any USB stick larger than 1GB! It recognizes a 4GB stick but will only format it to 1GB and won't see my 32GB and 64GB sticks at all even tho I can see and format it in Disk Management. I think this started after I did this to "debloat" W10: https://www.christitus.com/debloat-windows-10-2020/
Why not try "rebloating"? Just reinstall windows.
go to settings/update and security/recovery.
Look under the first item "reset this PC"
You can opt to keep your personal files etc.
What worked was changing the drive letter in Disk Management. Unfortunately I discovered that after resetting W10. Now I have a bunch of dead shortcuts and folders in the Start menu. Where is this data stored so I can delete it easily? Thanks.
