W10 adjust 2nd screen position
Denly
1,436
229
Hello, I did a lot of search before post. Upgraded w10 it is all fine and all except the 2nd screen position is off. it went over the top, 1/4 of the bottom blacked out. Any way I can adjust it? Bios screen fit on both screen, not sure if I wanted to do adjustment on monitor.
How to I send feed back to MS btw?
HP 6005 PII X4
A very old 512mb radeon card with DMC-59 DVI split cable.
Dell P2312 LCD x2
Ketchup
14,559
248
The screen resolution page in Windows lets you adjust the screen positions relative to one another. You may want to play with this, especially if your screen are different resolutions.
