happy medium
- Jun 8, 2003
- 14,387
- 480
- 126
Originally posted by: Kerby1280
Sorry to hijack this thread.
I had planned to do a mini-review on this card a month ago- but never got around to posting benchmark results.
Well since I've run into this thread- I can post my results for comparison with Goku's. The card was overclocked to 550mhz core speed and 700mhz memory speed- stock was 450mhz core and 625mhz memory.
System Specs:
Intel P4 3.2ghz Extreme Edition overclocked to 3.5ghz
Cooled by Zalman CNPS9500 LED
Asus P4C800 E-Deluxe
Gainward 7800GS+ Bliss 512MB DDR3 overclocked to 550mhz core clock and 700 memory clock
OCZ 2GB EL DDR PC-3200 Dual Channel Platinum
1x 150GB WD Raptor
1x 250GB WD Caviar 2500KS
Pics of set-up:http://i58.photobucket.com/albums/g246/Kerby1280/07d53769.jpg
http://i58.photobucket.com/albums/g246/Kerby1280/9b298a26.jpg
Pics of card:http://i58.photobucket.com/albums/g246/Kerby1280/5470638c.jpg
http://i58.photobucket.com/albums/g246/Kerby1280/07748cc3.jpg
http://i58.photobucket.com/albums/g246/Kerby1280/3fd55fee.jpg As you can see it has a 6-pin PCI-E power plug. You can use a PCI-E power plug if your PSU has one or use the included adapter which plugs into two regular 4-pin molex power plugs-http://i58.photobucket.com/albums/g246/Kerby1280/2f89023f.jpg
Benchmark Results:
3Dmark03- http://i58.photobucket.com/albums/g246/Kerby1280/Benchmarks/03.jpg
3Dmark05-http://i58.photobucket.com/albums/g246/Kerby1280/Benchmarks/05.jpg
3Dmark06-http://i58.photobucket.com/albums/g246/Kerby1280/Benchmarks/06.jpg
Lost Coast Stress Test: http://i58.photobucket.com/albums/g246/...enchmarks/hl22006-08-0702-22-00-21.jpg Test was run at 1280x1024 resolution and max settings(AA, Anti-Scopic, Textures, etc..)
Fear Performance Test: http://i58.photobucket.com/albums/g246/Kerby1280/Benchmarks/fear.jpg Fear had to be run at 1024x768- I don't remeber why but I think because it didn't have 1280x1024 as an option.
As for benchmarking games that don't have a built in benchmark demo- I did'nt have a method so I just took screenshots with FRAPS running in the upper corner to show FPS.
Battlefield 2- Gulf of Oman @ 1024x760- I don't remember why the low resolution. Screen shot was taken at the start of the level- http://i58.photobucket.com/albums/g246/...enchmarks/BF22006-08-0702-10-12-56.jpg
Call of Duty 2 (1280x1024 resolution)- D-Day stage where you're coming on shore and facing gunfire from the top of the cliffs. Shot was taken right after you get off the boat and there is a huge explosion to your right- http://i58.photobucket.com/albums/g246/...arks/cod2sp_s2006-08-0701-56-32-29.jpg
Well I felt I didn't do this card justice as I was running it on my cousin's 19-inch LCD(max resolution of 1280x1024) and wish I had brung my 20inch Dell 2005FWP(max 1680x1050). Running it at lower resolution tends to stress the CPU more- at higher resolutions the CPU will offload more work to the GPU. But I can tell you I had a chance to run this card with my 2005FPW a week earlier and I ran Oblivion on it at 1680x1050 and it was smooth as butter- sorry no screenshots.
There were a host of other games I wanted to do screen shots of- Oblivion, Quake 4, Black and White 2, Ghost Recon Advance Warfighter but I did not have enough time- I sold the CPU and motherboard two days after doing the benchmarks.
Lost Coast: settings all maxed 60.24 . You scored 78.95
Fear: 28min ,55avg.,146max 0% below 25, 34%from 25 to 40,66%above 40. You scored
28,45,70
Your Fear scores seem low. I have a 16 pipe 7800gs@502 core ,1.44 memory for these benchmarks.
We need a higher resolution test with a athlon 64 cpu for a the Gainward 24 pipe card
