I was just think if this would work better. I see a lot of post saying this case will only fit this size of rad or it will direct the heat back into the case because it needs to be but on the bottom of the case.
I was thinking why couldn't you mount as many rad's as you want outside the case mounted on the wall with a nice wood cabinet that goes around the side of the rad's . Stick the pump and reservoir outside in the wood case also. You could install quick disconnects (cut off valves) were the hose enters and exits the case too, so that you could pull your case out to work on it.
Doing this would keep the hot air out of your case and keep the cooler room air going to your intake side of your rad.
