I got a ViewSonic VX910 yesterday (some gaming, ok alot of gaming - just don't tell the wife) and wanted to know what the boards opinion was for using the sRGB color setting over the typical CRT color temps of 9300, 6500, and 5400.
If I select sRGB the ability to adjust the contrast and brightness using the OSD is disabled. The monitor is using a DVI cable.
Thanks.
Thanks.
