Vsync problems with my X800Pro running Painkiller and UT2004...
SickBeast
14,377
19
I have vsync forced in the drivers. These games don't have an in-game vsync option. Do any of you know of a way to edit their config files to force it?
SonicIce
4,771
Do you mean you forced it in the driver and it's still not on in the game?
To enable it in UT2004:
1. Run the game, open the console, and type: "preferences" (without quotes)
2. A little "Advanced Options" window will pop up
3. Click "Rendering", then "Direct3D support"
4. Scroll down and change "UseVsync" to True and "UseTripleBuffering" to True
5. You might have to restart the game for changes to take effect.
screenshot
BFG10K
22,709
3,003
Painkiller most certainly has a vsync option - "sync every frame" I think it's called.
SickBeast
14,377
19
screenshot
That was a splendiferous tip that obviously took you some time to compile for me. Thanks! :)
SonicIce
4,771
screenshot
Thats the kind of feedback I was hoping for! :) No problem bro
