[ VR-World ] REPORT: FIRST PICTURES OF SONY’S SLIM PS4 LEAKED
Majcric
1,386
48
Maybe in Microsofts case with the original Xbox 360 which isn't saying much. But of all the playstations ever released I'd much rather have the original than the chopped down slims.
Off the top of my head the same with original genesis, the slim lost features and buttons felt cheap in comparison.
CZroe
24,195
857
Original Genesis didn't have stereo output on the back (had to use the headphone port). Genesis 2 had S-Video, stereo, etc on the back. Who uses wired headphones with their wired controllers? I prefer the Genesis 2, though I have several of both. I do like that the 32X fits all the way in the original model Genesis.
Anubis
78,712
427
tbqhwy.com
the thing is already too small and lacks a large enough fan to keep it from running as hot as a toaster oven
I really do not think that is real
I however would like the current one to have a real power and eject button, not a fan of the touch ones
svarog19
32
I would only believe that if Intel decided to fabricate PS4's chip which is out of this world scenario while TSMC and other foundries don't have full scale 20nm or lower ready. This is obvious fake, from angle to design which is just a shrinked PS4 case and it would be a toaster and also it would need a complete redesign or otherwise it would be a ticking time bomb.
CZroe
24,195
857
It's totally possible with inevitable process improvements on the APU. Just think about a gaming tablet/notebook with the same level of performance and an SSD instead of a HDD. Sure, they'd typically be Intel, but Sony/AMD will eventually achieve that too, especially because they don't need as much internal power regulation (no display or battery; limited expansion).
CZroe
24,195
857
Seems impractical to have the optical drive and power buttons on the side.
Who says that's not the front? The sloped face with the logo is visible from the top in either orientation. Even if it is the side, it's not without precedents: When the original PS3 was stood vertical with the Playstation 3 logo right-side-up, the disc was put in through the side.
18,656
67
They really don't need to waste their time with this, PS4 is plenty slim and small (significantly smaller than the XB1, which is indeed going to have a slim version within the next year or two).
As said above, work on the OS, the straight forward UI is great already.
The point of the hardware revision is to reduce manufacturing costs. Not to make something smaller.
Fallen Kell
455
Except that Sony and AMD don't have a chip foundry that can make a smaller chip. It is already being build on TSMC 28nm line, which is their only production grade line to work with complex electronics like CPUs/GPUs/APUs. Their 22nm line is an utter failure still (which is why AMD and Nvidia havn't released a true next gen card in the last 3 years because TSMC can't get the process to work properly). TSMC's 22nm, 20nm, and 16nm lines that they have been developing are still only good for SD memory and the like.
And Intel sure as heck isn't going to lease out their foundry for rival AMD to make APUs on it...
RampantAndroid
6,591
Don't we have rumors that Samsung will be the fab for future chips from nvidia and AMD?
lamedude
1,206
10
PowerBase convertor is only fits Genesis 1. Nothing a Dremel can't fix though.
lamedude
1,206
10
Now I want to see a 32x, Game Genie, Powerbase, Master System Game Genie just to play a HuCard tower of power.
CZroe
24,195
857
I also inserted multiple Sonic & Knuckles lock-on carts with an extra-tall Virtua Racing cart and a Game Genie, 32X, etc when I was playing around. It was a monstrosity!
CZroe
24,195
857
Microsoft was able to get their chips made anywhere they wanted with the XBOX 360. Pretty sure Sony can do the same. Sony moved Cell manufacturing around multiple times with the PS3. IIRC, themselves, Toshiba, IBM, etc.
Ichinisan
28,298
1,235
With the slim versions usually come better consoles, cooler consoles, with larger hard drives. PS3 consoles lost features long before the slim version.
The top-loading PS3 ("super-slim") was an absolutely horrible-looking design. Joystiq / Engadget called it "beautiful" / "gorgeous" and all I could do was D:
I liked the PS3 slim (not the "super-slim"), but I had the 60GB will full PS2 compatibility.
Ichinisan
28,298
1,235
...there was an X-Band modem in the mix too.
exar333
8,518
8
The PS4 uses just over 100w (depending on workload), which is pretty similar to a high-end gaming laptop. The slim version, with appropriate cooling, should be perfectly fine to cool with acceptable acoustics. Hopefully they don't just make it smaller and crank-up the fans and make it loud. My original X360 and PS3 were loud, I don't want another console like that.
This is from someone looking to buy a PS4 in the near future, and I am hoping this slim also means HDMI 2.0.
Ichinisan
28,298
1,235
Since the PS4 doesn't have an LCD/battery/keyboard/trackpad, it can be smaller than a gaming laptop of the same wattage.
I read a while back that PS4 would come with HDMI 2.0 -- but I never bought one. When did they decide not to include HDMI 2.0 with the PS4?
ViRGE
Elite Member, Moderator Emeritus
167
Quick point of clarification: TSMC doesn't have a 22nm process (at least not one named 22nm). They have various 28nm processes and then 20SoC. You are otherwise correct though that 20SoC is not suitable for the console APUs; it's meant for small, low power SoC-type chips. The APUs are a little too heavy for the process.
We won't see an APU shrink until 16nm/14nm (depending on which foundry they use). In which case a 2015 refresh seems highly unlikely.
(Also SD/NAND memory is made on a different type of process than pure logic like the APUs)
Mar 11, 2004
23,250
5,693
Performance gains are approximately dick from installing a SSD in a console.
His point wasn't about performance but rather size (they could use the SSDs they put in laptops in there instead of a normal 2.5" one, or they could even solder the chips to the mainboard). But they won't (and definitely not a 256GB one) because the cost is still just too much. I actually though that one of the companies might go with 4GB of RAM and then like a 16-32GB of flash where they'd preload a bunch of assets onto the flash so they could swap it in and out of RAM quickly.
