VR build, can buy parts in US or UK
Juked07
1,474
I've been out of the loop for a few years, looking to build a decent box for exploring VR games within the next 1-2 months or so. As mentioned in the title, I'll be looking to try out some VR games, and probably some other VR experiences, for science.. Nothing else I use the computer for will be performance intensive.
For budget I am shooting for under $1500, but I could stretch to around $2000 if there is a compelling reason that I definitely should.
I'll be in the US (NY) for 6 weeks and moving to the UK after that. I'm assuming that buying parts in the US will generally be better, but I'm open to waiting til I'm in the UK for some parts if it means I'll get a better deal.
I'm not a devoted fanboy to any brand. I'm fond of understated cases of decent quality, such as Lian Li. I've mostly landed on intel, nvidia, mushkin, and a couple others, in the past, but I'm open to whatever the community thinks is best.
My existing parts are mostly just peripherals (Dell U3011 @ 2560x1600, KB, mouse, speakers). I may end up attaching a smaller second monitor. I preordered oculus rift also but it hasn't arrived yet.
I've never OCed before (never needed the performance), but I'm open to it if it makes sense here. I tend to value stability over performance at the margin though.
I probably need to buy a copy of Win 10. I have Win 10 on an htpc that I would be happy to replace with ubuntu, if that meant I could use my existing Win 10 key on a new box?
I'm not attached to any of these parts, but just thought I'd get the ball rolling with some proposals rather than asking you guys to do all the work:
GPU: EVGA gtx 1070? Or is 1080 worth the extra dough? Is AMD competitive in this category?
CPU: i5 quad core somewhere around $250 range? Is there a reason to go higher?
Storage: Mushkin Enhanced Reactor 2.5" SSD MKNSSDRE1TB for $205 on newegg? Is that a good drive? I like the convenience of not having to think about multiple drives
Cooler: Those self-contained liquid cpu coolers look pretty cool, if they're not just a gimmick. Any recommendations?
Case: Kinda drawn to Lian Li.. Probably micro ATX unless the build requires bigger for some reason. Budget maybe $150
MB: No idea, maybe expecting to spend $100-150?
RAM: No idea.. 16gb of something should be like $60 these days?
PSU: No idea, maybe $100?
EDIT: How does this look?? http://pcpartpicker.com/list/rCn99W
Sheep221
1,843
27
I won't go to all of your parts, but if you are questioning your overclocking intentions, you are better off with basic tower cooler like hyper 212, you can still get decent overclock on air. And in case of CPU, the unlocked i5-6600K will do fine for you.
Ken g6
Moderator
Dec 11, 1999
16,250
3,845
75
Here's a build derived from my $1000 build in the sticky:
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($339.99 @ B&H)
CPU Cooler: *Zalman CNPS10X OPTIMA CPU Cooler ($19.99 @ Newegg)
Motherboard: *ASRock Z170M Extreme4 Micro ATX LGA1151 Motherboard ($99.99 @ Amazon)
Memory: *Patriot Viper 4 16GB (2 x 8GB) DDR4-2800 Memory ($64.99 @ Amazon)
Storage: *Samsung 850 EVO-Series 1TB 2.5" Solid State Drive ($316.99 @ Newegg)
Video Card: *Sapphire Radeon R9 390X 8GB Tri-X OC Video Card ($379.99 @ Newegg)
Case: Corsair 350D Window MicroATX Mid Tower Case ($89.99 @ Newegg)
Power Supply: *XFX TS 750W 80+ Gold Certified ATX Power Supply ($59.99 @ Newegg)
Optical Drive: *Lite-On iHAS124-14 DVD/CD Writer ($13.89 @ OutletPC)
Operating System: *Microsoft Windows 10 Home OEM (64-bit) ($83.89 @ OutletPC)
Total: $1469.70
Prices include shipping, taxes, and discounts when available
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2016-05-22 11:23 EDT-0400
The 390X is a placeholder for the 1070, which comes out in maybe 3 weeks - although the 390X isn't really a bad card either. If the 1070 is delayed, you might have to wait and buy it in the UK, or buy a much more expensive 1080.
The 6700K should be significantly better than the i5 for at least some games; plus you don't have to overclock it to get to 4GHz.
I thought about lowering your PSU power; but this way, if one 1070 isn't enough, you can add a second in SLI. The motherboard and case also support SLI. You probably won't need it for now, but VR can be very demanding.
Juked07
1,474
Thanks for the replies!
I have been a bit busy so I haven't actually pulled the trigger on most parts yet, besides a 6700K that I picked up at microcenter last week.
What's difference would there be for me between the asrock mobo ken suggested and some random cheaper mobo like http://www.newegg.com/Product/Product.aspx?Item=N82E16813128873 ?
Also, will I be able to tell a difference between the samsung ssd and something cheaper like https://www.amazon.com/Mushkin-MKNS...id=1465749297&sr=1-1&keywords=mushkin+1tb+ssd ?
How does this look?
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($314.99 @ Newegg)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler ($49.99 @ Newegg)
Motherboard: MSI B150M BAZOOKA Micro ATX LGA1151 Motherboard ($69.99 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($49.99 @ Newegg)
Storage: Mushkin Reactor 1TB 2.5" Solid State Drive ($244.88 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Founders Edition Video Card ($449.99 @ NCIX US)
Case: Corsair 350D Window MicroATX Mid Tower Case ($99.89 @ Amazon)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ SuperBiiz)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer ($13.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89 @ OutletPC)
Total: $1452.49
Generated by PCPartPicker 2016-06-12 23:28 EDT-0400
