VOODOOo 3 2000 HELP!
dlrsuperman
224
I am having problems with my Voodoo 3 2000. The left side of my monitor flickers. I have no idea why. I tried changing monitors, but it still flickers on the left side. It's not so bad that I can't see what I'm doing on that side, but it's bad enough to be annoying. I am using the latest drivers for the V3 2000 version 4.12.01.0666 and 3dfx tools version 2.6.2.116. I have windows 98 SE, amd duron 700, msi k7t pro2-a. My monitor is a PROVIEW PRO720. Please help me! Thanks ahead of time.
rbV5
12,632
Check here, Voodoo files maybe they have a newer version, I use win2k and I'm using 1.04 V5 drivers and they work great! but I'm not sure about win98 other than there seemed to be more driver support for that OS for the V3.
Nullity
837
Are there any other monitors near that monitor? Or any kind of electromagnetic field? How about floresent lights? Big speakers (subwoofer or mid's)?
nightowl
1,935
Yeah, check for anything that might be causing EMI interference. I had the same problem awhile back with my old S3 Trio64. The left side of the monitor was jittering and I thought the gaphics card was bad, but it turned out to be a small electric clock that was causing interference with the monitor.
