voodoo5 owner i need some help
Mykex
380
V5 Mod You can get some Ideas here but the main thing is the 120 fan I have blowing from the bottom of the drive bays. I dont expect anyone to go as far as I did ;) but the bottom of the bay blower is a real easy solution.
Mykex
380
The pins don't line up so I used Artic Silver epoxy and I had to snip 2 fins on one because of capasitors in the way. I wanted to just grind them down but grinding wheel I used decided removal was the best way.;)
So no they dont fit,without help.
han888
1,586
i almost broke my capasitors on my card because i force to put blue orb on it, that's why i feel confuse why they can put the blue orb on the card
Mykex
380
Yes and if you force the use of the pins on the V5 with the Blorb the base of the Blorb tends to bend upward creating a pocket inbetween. Of coarse this is not good because you will get no heat transfer. This is why I used the epoxy,the frag tape would have been OK but I was uncomfortable just using tape.
RacerX
873
Mine has Stealth coolers ...they seem to work really well. It's never overheated or locked up once and I run at 183mhz pic here ---> Stealthy
Mykex
380
Yea those lasagna stealths are nice I just like the way the Blorbs looked. Yes I bought them cause they looked cool pretty dumb ehh. What I am kicking myself for not getting would be this V5 Kit That with the Artic Silver epoxy upgrade is 50$ kinda pricey but everything you could ever need is there.
