voodoo 3 problems help!!
alphatarget1
5,710
hey all
i bought a voodoo 3 3000 16mb AGP with video out but it has vertical stripes on the monitor (bought it from another forum) is there any way i can fix it?
BFG10K
22,709
3,002
The card might be overheating. Make sure you're not overclocking it. If not, try and underclock it and/or add better cooling to your system. Also try flashing it with the latest BIOS and check your cabling connections.
Of course it could also be that the card is defective.
