@@!!!@#@ volume icon in Windows ME system tray won't go away!!
Xray
How do you get rid of it.
In 98 you could get rid of it in audio properties but in Windows ME there is no box with a check mark in it. Whats up?
TGCid
Are you talking about the little speaker icon below the time on the taskbar? If so the check box is still there within sounds & multimedia icon in control panel. Works for me.
Xray
Thanks TGCid That worked!!
In Windows 98 you could just right clicked on the (As you call it) speaker icon and I could uncheck it in audio properties.
