the volume contral icon is not showing up in the taskbar. I have checked my setting in sound and device and made sure that the option "place volume control in the task bar" is selected.
the volume control icon appear after I enabled it,
however, everytime I log off and reboot the system, it's gone...
seems those ppl are having the SAME problem but NO solution... !!!
pls advice..
I am using win2k with sp2...
thanks
pls advice..
thanks
