Gophermofur
When people mention not to go above a specific voltage for a chip is it because:
(1) the temperatures will increase too much, and will subsequently make it difficult to adequately cool your chip, thus shortening the life span.
(2) The high voltage could kill your chip and the increase in temperature is just a by-product of the increased voltage.
(3) Neither?
I ask because if your chip is running quite cool, say 45 degrees under full load (hypothetical) and you are at the max range for your chips vcore... Is it safe to continue increasing the voltage as long as you can maintain a decent temp?
Btw, this is for a Core2Duo.
Thanks,
Mo
(3) Neither?
Thanks,
Mo
