I have my Vcore voltage set in Bios at 1.46v.
Any lower and it will not hold the Overclock on next cold reboot.
CpuZ shows this voltage on idle as 1.44v, and Vdroops to 1.41v in Orthos.
I'm assuming CpuZ figures are correct.
The below specs from Intel's website are for my Cpu.
Even tho they show the upper end voltage as being 1.5v,
does anyone think the 1.46v I've set in Bios will have any long term detriment to my E6750 Cpu?
And could I go to 1.5v if need be?
Temps on idle are round 36C (ambient 22C) and under load round 60C.
This is with a Tjunction setting of 100C.
Core2Duo E6750 Specifications
sSpec Number: SLA9V
CPU Speed: 2.66 GHz
PCG: 06
Bus Speed: 1333 MHz
Bus/Core Ratio: 8
L2 Cache Size: 4 MB
L2 Cache Speed: 2.66 GHz
Package Type: LGA775
Manufacturing Technology: 65W
Core Stepping: G0
CPUID String: 06FBh
Thermal Design Power: 65 nm
Thermal Specification: 72°C
VID Voltage Range: 0.85V ? 1.5V
sSpec Number: SLA9V
CPU Speed: 2.66 GHz
PCG: 06
Bus Speed: 1333 MHz
Bus/Core Ratio: 8
L2 Cache Size: 4 MB
Core Stepping: G0
CPUID String: 06FBh
