Hey, so I've gotten several GPU's in the past and I had a similar problem on all of them, also on my hd 4600 iGPU. Basically, at a certain point after using it the graphics go bonkers (from 1 day to 2 weeks of usage). Aliasing is horrible, jagged lines everywhere, AF not working, broken shadows (look very low quality). I recently RMA'd my gtx 960 due to this issue (still waiting for a new one, hopefully) but I've received some information from a guy who claims that this issue is a voltage issue, saying that buying a regulator fixed it.
I live in a house where electricity is really low quality and I was wondering, is it likely for this to be a voltage issue?
I'd invest in a regulator, but it'll cost me 50 and I was wondering if that is a worthwhile investment.
I was looking at this one:
BlueWalker voltage regulator: AVR 1000
A 600 watt regulator (should be enough, right? My system has a 650 power supply but uses 384 on 100% load).
Would this help in stabilising the voltages?
Another question; Would I need a UPS to properly regulate voltages or would an AVR be enough? UPS with sufficient wattages will cost me over 200 in my country and that's not really what I want to spend right now.
