M Medea Golden Member Dec 5, 2000 1,606 0 0 Feb 11, 2001 #1 What exactly do the readings mean under "Voltage" on the VIA Hardware Monitor? For example, right now, mine state: VCore Value = 1.80 3.3V = 3.32 5 V Value = 4.95 12 V Value = 11.89 CPU temp is 34 C. and system temp is 21 C.
J Jdog Senior member Oct 14, 1999 792 0 71 Feb 12, 2001 #2 It is simply a readout of the voltages. Yours are fine.
bolomite Diamond Member Oct 12, 2000 3,276 1 0 Feb 12, 2001 #3 Different components require different voltages. A little fluctuation is normal.
K kingz Golden Member Nov 7, 2000 1,623 0 0 Feb 13, 2001 #4 my vcore is at 1.92, when i set it to 1.85 in the bios. any ideas?
M Medea Golden Member Dec 5, 2000 1,606 0 0 Feb 13, 2001 #5 Thanks. I did a search for a in-depth discussion/explanation of voltage readings but nothing of use came up. Good to know that mine are okay.
