voltage help
thursday22dp
195
ok in my bios i set my voltage to 1.5 for my cpu yet when i look in the bios part with temps/fans/volts it shows it around 1.42-1.45 and it says 1.45 in nvidia moniter as well as cpu-z. I set it at 1.475 and 1.5 and still no changes
any help?
Dec 10, 2004
53
any help?
Mine reacts the same way. Could be that its based on demand. I can sense a difference though when I apply the increase to the cpu and the fsb. Still reads 1.40 vcore. I increased it to 1.55 and it was set to 1.50.
thursday22dp
195
what are you using? im using chaintech nforce4ultra and amd64 3500
il try upping my fsb, also if you are using same mobo/cpu aim me at thursday22dp
Dec 10, 2004
53
I have the MSI NEO2 Platinum Nforce3 Ultra with AMD64 3200+ and a gig of xms corsair ram 2x512. Has been only a few months of solid performance here! Have been playing farcry and tiger woods golf 2005.
