Voltage for OCing?
Flat
Banned
Jan 18, 2001
929
I have been overclocking a few 1ghz Tbirds with FSB & Multiplier, but have heard about changing the voltage for better results? can anyone give me an idea as to what to do with the voltage setting?
Spoooon
11,563
203
The idea is that giving a CPU more voltage will increase the stability of the CPU at a higher frequency. So, you start out by tweaking the multiplier and FSB. Go up in small increments at default voltage. Once you encounter instability, up the voltage a bit and repeat the process. I try not to go over +.2 volts. Figure out what gives you the most bang for your buck. On my CPU, I can get 1050 at 1.85 volts, or stick with 959 at 1.75 volts. A gigahertz is neat, but not worth upping the voltage that high. Increasing voltage increases heat produced and shortens the lifespan of your CPU.
