voltage for Corsair TwinX-3200LL?
yourdeardaniel
1,905
I'm running P4 2.8C @ 3.22 with 1.6 vcore and 2.65 vdimm. should i max the vdimm to 2.85v? attempting to hit 3.4 or 3.5 :)
myocardia
9,291
30
You'd be better off by just dropping your memory timings back to 2-3-3-6 or even 2-2-2-5, and running a 5:4 memory divider. 250 fsb will be running your ram at exactly 200 (400 DDR), and I'm willing to bet that too fsb at 2-2-2-5/6 will beat 250 fsb at 2.5-3-3-6, even if you can make it run that high with a CAS of 2.5.
edmundoab
3,223
www.facebook.com
well, if it is involving to change your ram timings and FSB,
then yes do bump it gradually,
otherwise keep it as it is if u can get stability.
ectx
1,398
I cannot run my twinx 3200LL at 230fsb... Need 2.8v to get them to 206 at 2 2 2.
If I were you, I would not hesitate to try higher volt. You should maximize you cpu oc first (by trying 5:4). Then find out the max of your memory by bumping up the volatage (1:1). Then compare the two to see which setting you like.
Unless you are very lucky to be able to run your memory to ~240-250 at 1:1, I'd think myocardia is right. Conventional wisdom is that you should maximize the cpu oc.
