And I can't for the life of me find any sort of voltage control in the bios? Does it exist via a secret menu or anything? Perhaps the latest bios? Just wondering if anyone else is running a mobile XP in this board.....
Its for a HTPC....i want it as cool as possible. Right now it is a running around 49-50ish full load on a $8 copper cooler and a 80mm panaflo. But I haven't stuck it in the cabient for torture testing yet....have a feeling I might have some problems.
If you don't have any voltage settings in the bios, you can always modify the cpu. But I was able to run my 2400 mobile barton at 200x10 with the default voltage of 1.45.
I can't seem to figure out how to change the voltage either. I tried searching for a Bios update that may have a better menu, but I have been unable to find one. One company wanted to charge me $70 for a bios update, but I told them that was just a little high. Maybe like $70 to high for me.
Does anyone know if there is a Bios Update for this board?
And if so, where?
